Old 09-24-2008, 09:56 PM   #1
OkieRA29
OkieRA29 is on a distinguished road
Default Getting duplicate keys made
I am in a quandry. I have an ignition key, but it does not match my door or hatch lock. Is there any way that I can get a toyota dealer to get me new keys? Am I reduced to finding mismatched sets through ebay?
OkieRA29 is offline   Reply With Quote
Old 09-24-2008, 10:55 PM   #2
mnewxv
mnewxv is on a distinguished road
toyota probably could make you some. Give your local dealer a call and go from there.
mnewxv is offline   Reply With Quote
Old 09-25-2008, 03:59 AM   #3
Grandavi
Grandavi's Avatar
Um... what car?
Skipping ahead... when you get a car, there is a keycode.. that comes with them (at least I know every car I had 2000+ has had it.. even the '96) Its a tiny tin dogtag, usually stuck with the driver's manual...
If not.. then the dealership can cut one from the VIN. And.. by the way, the old keys had different shapes.. one would do everything, one wouldnt do the hatch and glove compartment. If this is a MKIII, I believe you can get them copied but the key blank is usually a touch thicker than some kiosks carry. If your wanting the original, I am fairly certain the dealership can get one made. (then... before you actually do get one made.. check a locksmith. Sometimes they have solutions that are a lot cheaper)
Old 09-25-2008, 04:19 AM   #4
djfides
djfides is on a distinguished road
I just went through this myself and had a key made at the dealer. You can get a plastic covered head on the key or just regular metal. Just give the dealer your VIN number. Go ahead and get the key code too in case at some point the key code goes off their book (with older cars that can happen sometimes). The dealer will be happy to give it to you. Your car may have had a replacement ignition switch put in at some point and maybe they did not rekey the doors/truck at the same time. On my 1990 Supra I have one key that works in the ignition, door and hatchback. I am not sure how other models are. A professional locksmith could do it too, but I would start with the dealer. Good luck, you'll be ok!
djfides
djfides is offline   Reply With Quote
Old 09-25-2008, 06:48 AM   #5
Grandavi
Grandavi's Avatar
The dealer wanted $260.00 to cut keys for me, whereas the locksmith wanted $90.00. And here the locksmiths have the old keycodes...
Old 09-25-2008, 11:55 AM   #6
mnewxv
is that with new keys, as in with a chip inside?
Old 09-25-2008, 08:01 PM   #7
Grandavi
Grandavi's Avatar
was for my 88 Cressida, non-chip version. All keys. (I got them cut for free btw because I bought a AMA right before hand). The key disintegrated in the ignition barrel. (literally)
Old 09-25-2008, 10:47 PM   #8
OkieRA29
Ah,,, this is the car....
The car did not have any keys when I first got it. I got a key and ignition from the junkyard. The owners manual is long gone, so the key code is unknown to me. I will copy the VIN and try to get the key code from the dealer. Hopefully, I can then get keys made, but not if it is gonna cost me 250$!!!
Old 09-26-2008, 03:35 AM   #9
sd88supra
sd88supra is on a distinguished road
Default key code!
On the passenger door, there is a key code stamped on the lock cylinder. You'll have to dismantle the handle from the door to be able to read it. It will be a letter followed by four digits. Write it down (and store it somewhere safe!) and take it to a dealer. It will cost you all of $7 for a new key ($14 if you want a real Toyota key).
Yes, I too once lost my keys
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
sd88supra is offline   Reply With Quote
Help, Lost Keys scruffboy MKIII Supra 5 08-01-2010 01:04 AM
Home made Intercooler piping? mastergrader007 MKIII Supra 3 09-03-2008 06:37 AM
Poll: If Cooleeze made a CAI Pipes.... mkiiisupra MKIII Supra 9 02-05-2008 02:25 AM
Home made smoke screen sprigmo1 MKIII Supra 4 11-19-2006 08:46 PM
made a boo boo stairman Non-Generation Specific Questions 1 05-21-2006 05:13 AM
