#1 |
Hey guys... it's been a long time since i've visited but I have a few more questions
![]() 1. what is the item I circled in blue? just curious. 2. what is the hose called that I circled in red? that way when i'm asking around for a new one I know what to call it ![]() ![]() ![]() |
#2 |
The item in blue is the heater control valve. The open hose attachments are for the heater hose. It runs coolant to the heater core. The other hose is for crankcase ventilation.
#3 |
In the blue is the water valve diaphram
http://www.cygnusx1.net/Supra/Librar...aspx?S=AC&P=11 and the red is the water line for the heater core.
1989 5 speed turbo Koyo radiator Spearco intercooler HKS bov Greddy e-01 boost controller 245's all around Slotted + drilled all around 3" straight piping turbo-back, 4" tip Lowering springs HKS mushroom air filter |
#4 |
thanks for replys guys... but that cygnus page is not loading...
#5 |
have your dealership pull up a diagram of the cooling hoses and you can point to the one you need, its pretty specific and you arent going to find a generic hose that will work right
#6 |
AEM EMS
Go to this website and enter your vin # http://www.toyodiy.com
Search for heater hose and you should come up with the page in the link below. http://www.toyodiy.com/parts/p_U_1990_TOYOTA_SUPRA_MA70L-BLPVZA_8716.html?hl=87245A Toyota Part # 87245-1B251 This is for a left hand drive Supra (NATO US) ![]() The hose connects to the heater water union at the back of the head, part #90401-2204 ![]() |
#7 |
Wow great reply bill uk.. i'm going to bookmark that site for future use.. And on the topic of the hose I ended up just going with a generic heater hose from kragen cause I live nowhere near a toyota dealership... and it seems to suffice... stopped the leak for sure.
MK3 supra Hose Techniques silicon hoses | Micahwc | Shops & Part Reviews | 8 | 12-09-2012 09:03 PM |
Picture? Power Steering pressure hose | ptomko | MKIII Supra | 4 | 10-08-2008 02:19 PM |
Replacing Clutch reservoir Hose and fixing rock plate (plastic one) | Grandavi | MKIII Supra | 2 | 09-29-2008 04:49 AM |
7M-GE '86 Hose Connection Problem | pasupra | MKIII Supra | 3 | 08-04-2006 10:20 PM |
