Old 10-02-2008, 03:07 AM   #11
dannydavi
dannydavi's Avatar
Unhappy
thanks i've switched the two you suggested. Also I finished doing a compression check... and got some bad results
O O O O O O>>
2nd run was after adding a lil oil to each cylinder like suggested in the tsrm...
1st, 2nd run
O O cylinder 6
165, 190
O O
90, 150
O O
126, 157
O O
120, 180
O O
150, 168
O O cylinder 1
156, 170
so perhaps I waited a lil to long after my car was warmed up to get accurate readings on the first run... but also noticed the amount of oil you put into cylinder changed the compression reading drastically as well.... so all in all i've come to the conclusion I don't know what i'm doing lol. but I do feel there is something wrong in this area, possible bhg/worn rings etc near cylinder 5. any comments are welcome.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 10-02-2008, 03:50 AM   #12
CyFi6
were you holding the throttle wide open? how many times did you crank?
Old 10-02-2008, 05:27 AM   #13
dannydavi
dannydavi's Avatar
Didn't hold throttle open.... didn't know I was supposed to. tsrm I have didn't say anything about it and we cranked as many times until the needle stopped moving and reached it's max... roughly 5 I would say.
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 10-02-2008, 07:56 AM   #14
CyFi6
Try again and hold the throttle open this time, if you dont theres no way for air to get in there = no compression
Old 10-02-2008, 08:49 PM   #15
dannydavi
dannydavi's Avatar
dang mother F-er!! I wish it would have just said that... thanks for the reply, i'll let you know the results as soon as I get them.
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 10-02-2008, 09:45 PM   #16
paulmicin
paulmicin's Avatar
paulmicin is on a distinguished road
tsrm states that throttle body should be removed.
1989 5 speed turbo
Koyo radiator
Spearco intercooler
HKS bov
Greddy e-01 boost controller
245's all around
Slotted + drilled all around
3" straight piping turbo-back, 4" tip
Lowering springs
HKS mushroom air filter
paulmicin is offline   Reply With Quote
MK3 supra Hose Techniques silicon hoses Micahwc Shops & Part Reviews 8 12-09-2012 09:03 PM
Picture? Power Steering pressure hose ptomko MKIII Supra 4 10-08-2008 02:19 PM
Replacing Clutch reservoir Hose and fixing rock plate (plastic one) Grandavi MKIII Supra 2 09-29-2008 04:49 AM
7M-GE '86 Hose Connection Problem pasupra MKIII Supra 3 08-04-2006 10:20 PM
