My pressure hose was leaking so I bought a new hose. I am having some trouble getting the hose reconnected to the Gear box. I should have taken pictures. Anyway, there is a tab on the connector that makes it only connect a certain way, but when I do that the hose ends up laying underneath what I assume is a metal shield for a strut or something. This doesn't look normal. I was wondering if someone can take a picture of their last 10" of hose and connection to the gearbox? I've been looking around here for another Mark III that I can look under real quick and haven't seen any lately.
Paul |
#2 | |
![]() Quote:
In the mean time, if someone with the factory hose has some pictures I would appreciate seeing them. Thanks! |
I just installed one recently, more than once actually. It should be fine, the hose sort of curves off towards the drivers side slightly and then back across the car. It shouldn't have any issues with clearing anything, not sure what metal plate you are speaking of. Also, even with the metal tab there you can still rotate it a fair amount if i remember correctly.
Also, dont forget to use ATF, not power steering fluid.
#5 | |
![]() Quote:
I first tried the new washers that came with it, and it was devilish hard to keep that bottom washer seated while I tightened the bolt. When all was said and done, it leaked. So I used the old washers, which had a convenient tab between the upper and lower which held it in place. However, those leaked too. I am a little worried about tightening the bolt too much. Is the gearbox aluminum or steel? I don't want to strip the threads because getting a helicoil in there is almost out of the question without removing the gearbox. I think I have the metal ear as far as it will go clockwise, and maybe it has bottomed out and is preventing the bolt from tightening down further. I'll try rotating it a bit back counterclockwise. This will result in the hose heading off even more toward the driver side, but from your post that seems to be okay. |
Pressure Hose on Power Steering, first Supra and first post here. | ddouglas77 | MKIII Supra | 4 | 12-01-2008 04:15 AM |
Replacing Power Steering Hose - need help | xTomKx | MKIII Supra | 15 | 01-15-2008 06:34 AM |
Power Steering Return Hose. | teedoff00 | MKIII Supra | 4 | 11-28-2007 07:53 PM |
