Old 10-09-2008, 04:23 AM   #1
suprabahamut
Default Engine stalls
My engine starts to stall when I turn the steering wheel. I thought it might be a belt problem so I changed the belt but it still stalls. Is there anyone who knows or has had this problem? I was going to ask also if it is a bad pump can you just drive the car with one belt that just runs the alternator or will it mess up the steering components with out power steering? If I can drive with out power steering how hard is it to turn and is it legal?
Old 10-11-2008, 02:50 AM   #2
Kenny[NK]
Kenny[NK]'s Avatar
Kenny[NK] is on a distinguished road
I had the same problem. Actually still have. Check your power steering lines. Mine were leaking and causing the same problem. It's possible the pump is bad but more likely that the lines are bad. You can drive without power steering just fine but it will be harder to steer.
MySpace
MKIII
Kenny[NK] is offline   Reply With Quote
Old 10-12-2008, 09:22 AM   #3
paulmicin
paulmicin's Avatar
paulmicin is on a distinguished road
check to see if the idle up vacuum hose has come disconnected. its right under the intake tube.
1989 5 speed turbo
Koyo radiator
Spearco intercooler
HKS bov
Greddy e-01 boost controller
245's all around
Slotted + drilled all around
3" straight piping turbo-back, 4" tip
Lowering springs
HKS mushroom air filter
paulmicin is offline   Reply With Quote
