Old 10-11-2008, 04:29 AM   #1
EthanMKIII
EthanMKIII is on a distinguished road
Default Rattle of Death?
Well my cars engine has started to rattle i cant really pin point it. The rattle happens when its at 2000~3000 RPM matters what gear. It also does it when i shift. Its weird it only does it when the cars warm. At first i thought BHG but now im thinking timeing belt what do you guys say?
EthanMKIII is offline   Reply With Quote
Old 10-11-2008, 07:58 AM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Sounds like the big-end bearings have worn, check the crankshaft pulley hasn’t come loose first; this also can make a rattling noise. Read this post Link.
Old 10-11-2008, 05:56 PM   #3
EthanMKIII
There knock happens when its cold, mine happens when its hot. His raddle also starts at 1600 and stays. mines starts at 2000 then stops it only happens around 2000rpm.
Old 10-17-2008, 12:24 AM   #4
EthanMKIII
Well UKBill was right, it is the bearing what do i do now? Rebuild?
Old 10-17-2008, 09:22 AM   #5
CyFi6
if you are sure that is what it is, then yes, you will need to have the engine rebuilt. Do not run it any more, as it will just cause more wear and ruin parts that may be salvageable.
Death of a '91 Supra jimmyk Non-Generation Specific Questions 4 09-10-2008 03:14 AM
MK4 Targa/Sport roof rattle squeak noises mag MKIV Supra 1 08-27-2008 12:10 AM
Rattle noise back Trunk kkiepvvessau MKIV Supra 2 09-29-2006 01:48 AM
Hatch Rattle...anyone else? any fix? christutecky MKIII Supra 7 06-03-2006 02:53 AM
Engine Rattle .... Help! :) roscoa1 MKIII Supra 14 05-18-2005 02:13 PM
