Old 10-13-2008, 06:30 AM   #1
SilverBullet05
SilverBullet05's Avatar
SilverBullet05 is on a distinguished road
Default 7mgte swap ?
I have an 86.5 n/a 5speed i want to do a gte swap in looking at a 91 gte just want to know if it will bolt in, not sure about the mounts? Also the harness and ecu need to be the same your as the car or the motor any info helps please let me know thanks. Trying to figure out if it will all work before i buy the motor.
the only ? is will the 91 motor fit in my 86.5? or ar the mounts different? i dont want to buy the motor and not be able to use it.
ALL BOOST NO JUICE!
In need of some 7mge parts, let me know what you got.
SilverBullet05 is offline   Reply With Quote
Old 10-13-2008, 08:51 AM   #2
jrok
jrok is on a distinguished road
Default same
just wiring harness i think
1984 celica supra with 7mgte swap, custom intercooler, 2.5 exhaust no muffler or cat, shimmed wastegate to 12 lbs boost, with r154 turbo 5-speed tranny 16x8 xxr s13's with 245/50R16 toyo proxes 4's
.http://au.youtube.com/watch?v=rgOxP0PxCwo
.http://au.youtube.com/watch?v=uf989mb3EDw
also own:
2000 4runner 3 inch lift, 33inch tires
.http://au.youtube.com/watch?v=J15k1rCh7-A
1988 4runner stock
.http://au.youtube.com/watch?v=2u7e1_pMqfs
.http://au.youtube.com/watch?v=9lu4j5P6M7M
jrok is offline   Reply With Quote
Old 10-13-2008, 06:46 PM   #3
SilverBullet05
yah i found out everything bolts in i just need the pre 89 ecu and harness and plugs on the motor and thats all correct me if im wrong.
ALL BOOST NO JUICE!
Old 10-13-2008, 07:43 PM   #4
kwnate
Use the mounts off of your current motor.
Nate
7mgte swap no spark supra4life1386 MKIII Supra 5 11-27-2008 07:57 PM
7mgte Swap SilverBullet05 MKIII Supra 3 07-17-2008 12:18 AM
7MGE to 7MGTE SWAP! teedoff00 MKIII Supra 6 11-18-2006 07:58 AM
1986.5 N/A Supra 7mgte swap Posey MKIII Supra 0 03-16-2006 01:15 AM
Japanese 7mgte motors? Advice in swap? mark3supra MKIII Supra 0 12-04-2005 09:13 PM
