#1 |
I need to replace my pinion seal on my rear diff. Any pointers? I have the pinion seal and side differential seals ordered.
#2 |
If you haven't done so yet, get the http://www.toyota-supra.info/forums/...9950-tsrm.html
I suggest you get access to air tools, especially a good impact wrench. The pinion flange bolt is a serious PITA without one. The factory torque setting is 134 ft-lbs. And yours has been on there for at least 13 years. It will not come off easily. Did you get a new spacer/crush sleeve? These are also suppose to be replaced when the pinion nut is removed. This guy is important to set the proper pre-load on the pinion bearings. Some shade-tree mechanics go ahead and re-use the old one, but most professionals say it is a No-No, and will lead to quick failure of the pinion bearings. I say, replacing it is cheap insurance. For the rest, follow the TSRM. P.S. Air tools only to remove. Use a torque wrench to reassemble. |
Thread Tools | |
Display Modes | |
Rear Main Seal | mkiiisupra | MKIII Supra | 3 | 09-28-2007 02:31 PM |
need help replacing 89 supra front and rear brake pads | 89supra323 | MKIII Supra | 16 | 05-25-2007 12:43 AM |
1991 Supra - Water in Rear Wheel Wells | unkymurch | Non-Generation Specific Questions | 7 | 03-02-2007 12:59 AM |
Replacing rear hatch lifts | Staceman | MKIII Supra | 4 | 12-07-2006 02:50 AM |
rear seal blown | frankie_lala | MKIII Supra | 2 | 09-02-2005 06:12 AM |
