Old 09-15-2008, 06:37 PM   #1
Scionguy
Scionguy's Avatar
Scionguy is on a distinguished road
Default (fixed)alarm? starter?
hey my 89 non turbo likes to kill the battery after sitting for a few days, and today when i went to start it, it was dead as usual, so i hooked a jumper to it, and the alarm started to go off? never done that before, and so i had to put the key in, to the on position, and then the alarm stopped. but now it wot turn over, with the charger on charge/start, it wont even click to turn over, its only been on for like an hour, but did the alarm do something? becuae the clock lights will dim when i try to start it, but thats about it. and my alarm is wierd, its some kind of chip thing you pull out of the steering column, is that how they all are?
it was the alarm.
89 n/a(on her way to being pretty agian)
04 xb(40 shot, soon to be boosted)
60 ranchero( pure blesphemy dropping in a 2jz-gte going bpu++
Scionguy is offline   Reply With Quote
Old 09-15-2008, 11:04 PM   #2
Grandavi
Grandavi's Avatar
gonna guess here and say that you have a wiring fault. First sign is the dead battery. There is a switch you can buy (cant recall name but I will see if I can find it) that prevents your battery from being drained. It auto-switches. The bad thing is... now you have to hunt for what the problem is... no easy task that.
Wish I could suggest a magic answer, maybe someone else has seen something similar.
Old 09-16-2008, 02:04 AM   #3
Supra Greg
Supra Greg's Avatar
Supra Greg is on a distinguished road
Well you can try this...charge the battery... unhooked from car... hook up lock unlock car with key.. then it should start...
Now you need a test light... get a cheapy from walmart.. few bucks...
unhook the negitive cable to the battery... hook one end of test light to the battery (neg) the other end to the (neg) cable ...
if the light is real bright.. you have something drawing power... try to put test light were you can see it from inside car..
start pulling fuses ... inside and out.. till the light goes out... unplug the clock fuse first.. and the door ajar thing... when door open its gona turn lights on so it pulls power...
anyway you should get a idea on what you need to do to isolate the issue with the draw on battery...
Greg... aka Hommersimpson :}
Supra Greg is offline   Reply With Quote
Old 11-04-2008, 08:35 PM   #4
wizeguy707
wizeguy707's Avatar
wizeguy707 is on a distinguished road
Default Need Help
This will be a lil reading, same problem here. I had to have my tranny pulled for some work and a new clutch. The auto shop put it back in. No known problems to me for about three or four days. Then I got out of work one night only to have my battery dead as a door nail. I jumped her, and got home. I left it running a while thinking it might have been a rare chance. killed it and cut it right back on w/ no problem. Came out the next morning to the same thing. So, first thing was replacing the battery since I knew the altenator was good. Went about my marry way. Only to figure out the next day that my problem was still there. I had also gotten some replacement factory speakers installed at which point the guy happened to knock my key assembly to the hatch in where I can't get to it. Figuring this might be the problem I bypassed the alarm system(or tricked it to making it think the door was open, so the alarm wouldn't engage) No such luck. Dead the next time I came out to it. NEXT, I tried making a kill switch for the battery, and ran the switch into the car. I had two cables connected to my positive ( one to the starter, one to everything else). I tried hooking both up seperately with no luck again!!!! I tried hooking them up together to the switch which bit me in the ass( too much voltage fried the switch). So, now I'm to the point I'm going to pull my hair out!!!! Any clues??? I just can't get ANY battery to hold a charge in this car even after cutting the power in both directions. I had read about a piece attached to the back of the altenator that regulates voltage...could this be the problem???
wizeguy707 is offline   Reply With Quote
Alarm System mrnickleye MKIII FAQ 1 07-20-2010 04:08 AM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
90 mkIII starter connections doodah MKIII Supra 1 11-11-2008 06:14 PM
How to quickly test starter CyFi6 MKIII Supra 4 11-30-2007 01:57 AM
Car alarm/ car starter bigal0043 Car Audio and Alarms 7 10-22-2005 02:10 PM
