Old 11-06-2008, 05:30 AM   #2
shiftysupra
shiftysupra's Avatar
shiftysupra is on a distinguished road
yes they do have one (BOV) and you will hit fuel cut around 10 psi... you should upgrade to a KVM (MAF) and 550cc high impedence fuel injectors. You could use RX-7 88-92 turbo (series 4 I believe) injector with the maroon tops... That should get you around in the 14 psi range. However you really need to replace your HG to a MHG first to handle the boost or you will blow it by raising the boost now. I would also really recommend at least upgrading the down-pipe. You can gain around 20hp with that.
shiftysupra is offline   Reply With Quote
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
