Old 11-11-2008, 12:26 AM   #1
kidsusukigsxr
kidsusukigsxr is on a distinguished road
Default Idle Problems
Hello this is an 89 manual non-turbo supra. The last thing i did to it was a head gasket about 8 months back. It was successful. My first one ever.
The problem I have is that while stoped at the light the engine idle drops and the car seems like its going to stall out and the dash lights, just about to come on and the car kicks back on and idles little over 1000 rpm then repeats all over again. this happens steady over and over.
While driving this problem doesn't happen.
Any suggestions.
89 Supra Non-Turbo, Manual, Blue
88 Supra Turbo, Auto, Black
kidsusukigsxr is offline   Reply With Quote
Old 11-11-2008, 02:19 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Does it do from when you first fire the car up as well or only after you've driven it? It sounds like you may want to check to make sure that your vacuum lines are still connected properly and that they don't have any crakcs in them... I'm sure some other more experienced people will have more suggestions.
Old 11-11-2008, 11:06 PM   #3
kidsusukigsxr
Thank I'm looking into that since your suggestion. Do you have or know where documents / photos are on vacuum line setup.
Old 11-11-2008, 11:44 PM   #4
Busted Knuckles
Busted Knuckles's Avatar
Yup, sounds like a vacuum leak. Check all the lines.
Old 11-12-2008, 05:17 AM   #5
btwilson86
Super Moderator
btwilson86's Avatar
Sure, here it is: Vacuum Piping
This should give the location to most all of the lines, I think there might be a couple from some system not shown.
won't idle 3.0trd MKIII Supra 6 06-15-2009 07:23 PM
Having some idle problems...please help, details inside noredline MKIII Supra 6 09-18-2006 11:38 AM
problems, problems, and problems tone loc MKIII Supra 6 09-06-2006 04:35 AM
turbo 3 idle, vsv advice wesbam1 MKIII Supra 1 05-10-2006 08:07 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
