-   -   89na cam placement. (http://www.toyota-supra.info/forums/mkiii-supra/12702-89na-cam-placement.html)
johnson8375 11-24-2008 06:20 AM
89na cam placement.
Im in desperate need of anyone knowing how the cams are placed on a 89 supra non turbo the marks got removed and I have no idea how to install them back in please help!
CyFi6 11-24-2008 06:49 AM
Put the locating dowel pin in the center hole of the cam gear, the cam gears have an indented dash mark that should be pointing strait up, theres no wway it could have gotten removed
johnson8375 11-24-2008 07:46 AM
89na cam placement
its the actual cams that i need to know how to put in?
johnson8375 11-24-2008 07:47 AM
never mind I got it thank you so much!
