Old 12-05-2008, 09:26 PM   #1
dannydavi
dannydavi's Avatar
Default prepping block for headgasket question
hey guys I have a question about how you guys got your block ready for your HG repair? So far I have used an abrasive bad on a pneumatic gun. it did a great job on the intake side of the block, but on the exhaust side there seems to be a lot more shit on the block, is this something you came across as well? would you guys use a soft wire wheel at any point? any suggestions help, thanks.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 12-06-2008, 07:44 AM   #2
CyFi6
I definitely suggest you don't use a wire wheel. Just use a blade scraper to get the stuff off. I believe they have a gasket removing liquid also, you let it soak and it makes removing it easier. I removed all my gasket material with a scraper blade. You want to be extremely careful with air tools as it could make the surface uneven without being able to see it.
HELP!: 7MGTE engine block info needed barton MKIII Supra 1 05-19-2010 05:54 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
HELP!: 7MGTE engine block info needed barton MKIII Supra 6 04-14-2010 09:28 PM
Plug or hose came off back of block f00g00 MKIII Supra 3 05-20-2006 11:01 PM
