Old 12-07-2008, 02:01 AM   #1
dieseltech24179
dieseltech24179 is on a distinguished road
Default code 12
ok i did a diagnostic check on my 88 7mgte and i got quite a few codes but im doing them one at a time so up first is code 12 it says the distributor or cam pos sensor circuit or the distributor or cam pos sensor or the starter signal circuit. so its not the distibutor ( i dont have one lol). would the cam positioning sensor being out if adjustment or installed wrong be the problem?
dieseltech24179 is offline   Reply With Quote
Old 12-07-2008, 02:38 AM   #2
dieseltech24179
Default code 12
and there is a new engine harness so it couldnt be the wiring
Old 12-07-2008, 05:53 PM   #3
dieseltech24179
Default efi fuse
ok so i pulled the efi fuse just to check to see if any codes would go away and all of them did except code 32 and 51. idk if when i get the car running again that the previous code 12 and 42 will come back but for now im just worried about these two. 32 seems simple enough since my engine harness is brand new then it has to be the AFM itself failing instead of the wiring being crappy. so i guess its safe to go on and buy a new one or used cuz ebay is my friend lol. also would the AFM cause spark plugs to foul?
KS code, and no KS connector? Scionguy MKIII Supra 5 08-28-2008 08:15 PM
code 14 and 52 west_side_supra MKIII Supra 30 06-02-2008 05:04 PM
Where EXACTLY is the key code? finaltable MKIII Supra 6 08-12-2007 01:26 AM
still the getting code 52 whitequasimodo MKIII Supra 9 11-17-2006 12:34 AM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
