-   -   water temp gauge install (http://www.toyota-supra.info/forums/mkiii-supra/12795-water-temp-gauge-install.html)
sundevil1 12-07-2008 10:07 PM
Where do i install the temp probe?
CyFi6 12-08-2008 02:11 AM
in the water neck
ddmcse 12-08-2008 11:44 AM
i put mine in the block . exhaust side outside of #6
under the exhaust manifold there is a capped off drain . threaded
Chambers 12-09-2008 04:38 PM
I have seen a sensor in the radiator hose on a few different vehicles. They cut a certain portion out and put a metal pipe there, then thread the sensor onto that with a bung. Just have to be carefull about the wire near the cooling fan.
