I have an 89 Supra and i want to fix my tail lights.
for one thing, when i turn the left signal on, the right signal light comes on in the rear as well (while the left signal light is signaling also, so it looks like i have hazards on) this also happens when i signal right, it still looks like i have hazards on. another thing that i noticed is that the turn signal lights are dim when they are on. i am also curious to know what the farthest light is for (i know the first 2 are for the brakes, the 3rd is for the signal, but the one in the corner?) if anyone can help or give any suggestion on whats up with my car, that be niice =] btw, can this be a faulty ground that is causing this oddity in my mk3? |
hopefully your good with a test light or power probe....
first check all your fuses start disconnecting the rear light connectors (the main harness, where all the wires go into) unplug it and try the signals... see if the left and right are still going at the same time (judging by the front markers) do that also for the other side.... maybe your shorting inside one of the connectors most likely... if thats not it, then you gotta start checking wires starting at the lights and make your way to the multifunction switch..... maybe its your switch... see if the switch is sending power to the left and right wires at the same time.... other than that, get a schematic and go to town... hopefully your in a warm climate.... 32degrees here |
thanks for the advice, i'll mos def check those fuses again and see whats up. btw, what do you mean by multifunction switch and where would it be located at?
thats what the switch is called that does your directionals and headlights, highbeams and so forth... the stick like thing sticking out the left side fo your steering columb(sp?)
tail light | Subjug4tor | MKIII Supra | 5 | 05-03-2008 03:41 AM |
Grounds for the left tail light | supraman121 | MKIII Supra | 1 | 11-08-2007 12:57 AM |
Tail Light Changing? | newbsupra | MKIII Supra | 2 | 05-21-2006 04:07 PM |
Tail light conversions..need help | TargaMKII | MKII Supra | 8 | 02-28-2006 06:05 PM |
battery warning light / tail lamp failure warning light | MattJ | MKIII Supra | 5 | 02-06-2006 07:22 PM |
