Old 12-13-2008, 07:42 PM   #1
supraduper
supraduper is on a distinguished road
Default whats more common? wrist pin,rod,or bearing noise?
as the title says... whats more common on these engines 7mge...
i have a light knocking noise under certain conditions (2200 rpms light load, up as far as ive gone 4000 rpm)... to me it sounds like a wrist pin...
is this unheard of?
whats common on these motors?
supraduper is offline   Reply With Quote
Old 12-13-2008, 11:26 PM   #2
CyFi6
do you hear it at idle? Does it sound more like a double knock or is the speed of it consistent? You could also have valve noise. Theres really a lot of things that can make knocking noise including a cracked flexplate etc..
Old 12-14-2008, 01:24 AM   #3
supraduper
noise is not at idle... runs smooth, aside from the oem wires, which make it skip a lil...
noise is heard when cruising at a steady speed, with the rpms above 2k...
again light throttle crusing speed, its like a rattling sound.... if i gas on it gets a little louder and subsides shortly untill i get above 3k. then it gets more rapid the higher the rpms....
it does have the sound of a wrist pin, as in its maybe a double knock... but i hadnt heard of anything like that with these engines, just the crank bearings....
is this possible to have a bad wrist pin with 117k on the motor??
Old 12-14-2008, 01:28 AM   #4
CyFi6
Anything is possible. Get a mechanical oil pressure tester gauge and check your oil pressure.(not the stock one)
Old 12-14-2008, 01:46 AM   #5
supraduper
i have one... im a mechanic... so i have an idea what im listening to... but i come from honda world.... this is my first toyota..... and what a f'n ride.... so much torque... its more like an american muscle car than an import
but yea.... oil pressure is good... at least its not super low
i was trolling craigslist and it seems that most of them on there have engine noises in the lower end.... can they not take the abuse?
Old 12-14-2008, 01:53 AM   #6
CyFi6
The 7mge should last you many many miles, just depends on how it was previously maintained. Use a stethoscope to further narrow what the noise is. As i said it could be a multitude of things... Its not like the 7mge has a tendency to do any one thing. How it was treated in the past dictates what has happened now, there's nothing else to really say.
Noise From The Trunk Help krupt_01 MKIV Supra 1 02-19-2009 10:47 AM
unknown noise hkssupra MKIII Supra 5 09-22-2007 11:59 PM
Terrible noise from the Drivebelt area 94TT MKIV Supra 2 12-04-2006 12:29 PM
exhaust noise toonen Non-Generation Specific Questions 2 05-19-2006 11:27 AM
help on knock knock noise Guest MKII Supra 3 05-31-2005 07:41 PM
