Old 06-17-2008, 06:07 AM   #1
Sinistral
Sinistral is on a distinguished road
Default Car squeaking, please help
Within the last few days my '87 has developed a squeak. I've been able to narrow it down to the left side, but I'm not sure if it's a front or rear issue (or both).
I'm almost positive it's not the brakes because the squeak is constant. It actually seems to have gotten worse (or more apparent) as time goes on, which has me worried. It seems to be more audible at lower speeds, although I suppose that could also be due to less tire/wind noise.
Anybody out there have any ideas on what it could be? And if so, any solutions?
Sinistral is offline   Reply With Quote
Old 06-17-2008, 07:56 AM   #2
CyFi6
Does the noise stop when you start pressing on the brakes?
Old 06-17-2008, 02:18 PM   #3
Sinistral
No, and it doesn't intensify either.
Old 06-17-2008, 07:17 PM   #4
edmonton
edmonton's Avatar
edmonton is on a distinguished road
is it coming from inside the car or outside?
edmonton is offline   Reply With Quote
Old 06-17-2008, 08:29 PM   #5
Sinistral
Outside, but not to worry, I took it by the mechanic today and turned out it was the front brake pads. They've been replaced and all is well.
Old 01-10-2009, 05:47 AM   #6
Serge
Serge is on a distinguished road
I have the same kind of problem on the same wheel but new brake pads didn't solve the problem at all....Would you please ask your mechanic about real source of that sound?
Thanks!
Serge is offline   Reply With Quote
Old 01-10-2009, 05:57 AM   #7
Serge
One more detail...I have found that my front brakes do not have any Anti-Squeal Shims at all..... is that normal?
Old 01-11-2009, 12:22 AM   #8
Busted Knuckles
Busted Knuckles's Avatar
No. That's not factory spec. The brakes should have anti-squeal shims if you don't want the squeaks to return.
Old 01-12-2009, 05:00 AM   #9
Serge
okay thanks! I have ordered those already...
Old 01-18-2009, 05:35 AM   #10
Serge
after installation of new front brake pads with new shims the car is still squealing (left side)...maybe that is bearing...how would I identify that?
Thanks!
Squeaking from engine? merryprankster Non-Generation Specific Questions 0 06-23-2007 10:19 PM
