Interesting power loss problem!
Ok guys, I am new to this forum also to MKIII Supra. I bought this car last week for $70. One owner with 103K miles. Its been sitting for years so It took a while but finally started. Problem is, It doent wanna Idle and when I play with the throttle cable there is no response from the engine. wont rev up pass 1000RPM. I messed around with the timing and retarted the engine and it started revving up to 2000 RPM. Do you guys have any ideas what could be the problem? I checked for the vacuum leaks and there is no leaks. Fuel pressure seems fine. I get very less engine response.
Or is there a way to check the diagnostic trouble codes without having a scanner? some manufacturers usually shorts some connections and the check engine light blinks so many times and those blinks refer to a code- do supras have a system like that? like I said I am new to Toyotas and I will really appreciate your ideas or advises. |
look here. scroll down to FI-23 and you will se info about the diagnostics codes.
http://www.mauri.se/TSRM/07_FI.pdf |
How to enjoy movies and music easily in 2009? here i have some good tools to share with you.
Mac DVD to iPhone DVD to iphone Converter for Mac DVD to iPhone for Mac iSkysoft DVD Studio Pack for Mac iSkysoft DVD Ripper for Mac DVD Creator for Mac Dvd Copy for Mac |
see?!?! this crap^^^ happens when there are no moderators.
So did you fix your issue? |
The worst thing you could ever do imo is actually follow the links. That would just be silly because its like buying stolen goods.. you just fund the criminals I just click on the triangle with the ! on the left side of the post.. type in spam... and then he knows exactly which ones to go to. |
