-   -   Lipp Fuel Rail Problem (http://www.toyota-supra.info/forums/mkiii-supra/12957-lipp-fuel-rail-problem.html)
sprigmo1 01-07-2009 01:08 AM
I purchased a set of PTE Delphi 780cc Injectors for my 1992 Toyota Supra Turbo, and I cant for the life of me get them to not leak after installing them in my LIPP Fuel Rail. Any suggestions??
dannydavi 01-09-2009 12:40 AM
umm.. not to familiar with those.. is it leaking from the injectors or the rail itself? and if injectors, is it leaking from all of them?
sprigmo1 02-24-2009 02:20 AM
Leaking from the o-ring side. Just #6!!
tsupranami 02-26-2009 06:03 AM
You've replaced the o-ring, correct? If they go in wrong even once they'll leak 4ever. Are you using OEM Toyota o-rings/seals or aftermarket? I've found the aftermarket ones run a hair smaller, so I soak them in gas for an hour or two so they swell up and soften a little before I install them.
