#6 |
Well, in my experience and word from others, new thermostats sometimes fail, I would try that first. If you are wanting to go with a aluminum rad, make sure you do not go with the cheap ones, they will not bolt up with the stock mounts. If its going to be a while, then I would see about putting the stock fan and clutch assembly back in, with a new thermostat. Hope this helps, good luck.
problems problems problems.... | 86SupraMan | MKIII Supra | 5 | 02-04-2008 04:28 PM |
Starting problems and accleration problems! | alekjame22 | MKIII Supra | 6 | 03-17-2007 11:19 PM |
Oil leak problems | adellicson | MKIII Supra | 1 | 03-04-2007 10:11 PM |
problems, problems, and problems | tone loc | MKIII Supra | 6 | 09-06-2006 04:35 AM |
Distributor problems? | ekoston69 | MKIII Supra | 1 | 02-02-2006 11:29 PM |
