Old 07-19-2005, 03:46 AM   #1
MikeMcSomething
MikeMcSomething is on a distinguished road
Hey guys im new here and have a problem -
I recently started fixing up an 88 N/A that had a battery blow up and melt the fuse block, igniter, and parts of the wiring harness. I repaired the wires, put in a new igniter and fuse block, and replaced the dry-rotted intake hose and vacuum lines, and replaced the distributor. Now when i start the car, it runs great for about 3 seconds, and then dies on me. Has anyone had something like this happen to them?
MikeMcSomething is offline   Reply With Quote
Old 07-19-2005, 03:50 AM   #2
MikeMcSomething
Fuel injectors are good, all sparks are good, timing is fine - the engine runs beautifully and then just quits, and I can start it immediately after it dies with no problems.
Old 07-19-2005, 05:05 AM   #3
Guest
Guest
Posts: n/a
Check fuel pressure, and possible fuel pump not getting voltage except in the 'start' mode.
Old 07-19-2005, 08:05 AM   #4
MikeMcSomething
We jumpered the fuel pump so it gets a solid 12V constantly, fuel pressure seems fine as the car can be started as soon as it shuts off.
Old 07-19-2005, 10:26 AM   #5
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
have you tried a diagnostic yet?
that may tell you what area is malfunctioning
Pics of my build.
Do a diagnostic first!
Old 07-21-2005, 09:51 AM   #6
MikeMcSomething
Negative, haven't really been able to tow the thing to a dealership. I heard its possibly fuel, and that my cold start injector fires enough fuel for the vehicle to run for a few seconds and then the regular injectors can't pick up the slack, how does that sound?
Old 07-21-2005, 11:06 AM   #7
suprra_girl
7M POWAH! ;)
don't need a dealership for our cool cars
in the engine bay on the strut you should see
jump T & E1 or TE1 & E1
go turn the key on to Ignition and watch your check engine light
if it blinks quickly and constantly no codes
if it blinks in random fashion.. you have codes
eg. 21 = blink blink.... blink
34 = blink blink blink..... blink blink blink blink
let us know what codes ya come back with
Pics of my build.
Old 07-22-2005, 08:02 AM   #8
MikeMcSomething
We tested that awhile ago and we dont get any codes when the car dies. When we jumper the diagnostic terminals the car actually runs for about 6-7 seconds instead of 2-3, its a consistent improvement in the run time kinda wierd.
Old 07-22-2005, 09:40 AM   #9
suprra_girl
7M POWAH! ;)
when you do a diagnostic you shouldn't have the car running, the key should be to the "on" position but not running
what does your check engine light do?
for the car to stall there must be a code that the ecu has stored
Pics of my build.
Oil Pressure...Mechanical or Electrical??? Luvs2slide MKIII Supra 5 08-23-2006 12:42 AM
Question About Turn Signal? and a few more small Qs! V1P3R Non-Generation Specific Questions 8 08-08-2006 04:45 AM
Intermittent Electrical Problems on a ’93 MKIV gjs_cds Shops & Part Reviews 0 05-22-2006 02:39 PM
1980 Supra with electrical question. Zebian2 Non-Generation Specific Questions 0 11-13-2005 10:13 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
