Hi, I have an 87 NA and an 88 NA, both of which have the Knock Sensor Engine Code. On both cars the wiring is still intact, meaning from plug to ECU pin I have continuity. So I am wondering if anyone knows how to bench test a Knock Sensor to see if it's faulty.
Any ideas or links would be appreciated.
at 2000 rpm hit the intake the timing should change or to bench test when you strike it it should produce some electricty but very small....problem usually in the wiring, check wire to ground, the outside of the wire should be grounded.
1984 celica supra with 7mgte swap, custom intercooler, 2.5 exhaust no muffler or cat, shimmed wastegate to 12 lbs boost, with r154 turbo 5-speed tranny 16x8 xxr s13's with 245/50R16 toyo proxes 4's .http://au.youtube.com/watch?v=rgOxP0PxCwo .http://au.youtube.com/watch?v=uf989mb3EDw also own: 2000 4runner 3 inch lift, 33inch tires .http://au.youtube.com/watch?v=J15k1rCh7-A 1988 4runner stock .http://au.youtube.com/watch?v=2u7e1_pMqfs .http://au.youtube.com/watch?v=9lu4j5P6M7M ]
Picture Of Knock Sensor Locations | ravenmaster | MKIII Supra | 10 | 01-31-2012 03:37 PM |
KNock Sensor | ZauggIt1 | MKIII Supra | 0 | 12-17-2006 05:22 PM |
Knock sensor for an N/A. | rnoswal | MKIII Supra | 2 | 11-16-2005 05:12 PM |
Knock sensor..........ebay. | rnoswal | MKIII Supra | 0 | 11-06-2005 07:24 PM |
Bad Knock sensor | TWRViper | MKIII Supra | 5 | 08-31-2005 09:24 PM |
