Old 02-06-2009, 07:55 PM   #1
RawrXTC
RawrXTC is on a distinguished road
Default Question about AC
In a 89' turbo mk3 does the AC only work on low and medium settings and not high? I was looking at one the other day and the AC worked fine on low and medium but i put it on high the ac light goes out. Was just wondering if thats normal.
RawrXTC is offline   Reply With Quote
Old 02-07-2009, 03:31 AM   #2
RawrXTC
Anyone at all? :X
Old 02-07-2009, 05:06 AM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Can't tell you for sure as I no longer have my supra, but I am 95% sure that it is supposed to work when the climate control is set to "High". Also make sure that the climate control is set to a low temperature, like 65 degrees.
Good thing to check is to see if it's just a light issue on the control unit. With the car running, turn your AC on in a setting that you have found it to work. Pop the hood, and look at your AC compressor. You should see that the clutch has engaged, and that the compressor wheel is spinning. Now set the control to "High" and check the compressor wheel again. If it's not spinning, then your AC is malfunctioning in the "High" mode. If it is spinning, then your control unit indicator lights are not working properly.
Hope this helps you out.
Old 02-07-2009, 05:14 AM   #4
RawrXTC
Thanks for the reply. I'll do that when i take another look at the car.
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
