Old 07-22-2005, 04:41 PM   #1
Damian
Guest
Posts: n/a
Long story short... the fuel line on the other side of the fuel filter (not the side that goes to the pump) is damaged near the end. I went to many auto parts stores only to find that none of them had the right size bolt and line to fit the filter. I went to toyota and they said it would take a month or more to get the part, and it would include the whole fuel line which was around $60.00.
I can probably take the part to the hardware store and have them remove the damaged line that is stuck inside the bolt. Then buy a couple inches of brake/fuel line and cut off the other damaged part that is still on the car, and connect the two ends.
I can either do that, or find a site that sells the whole line with the connectors on the ends. I have been looking but I can't find any.
If anyone has any sites or feedback to my situation, please let me know.
priddy@hartford.edu
Old 07-23-2005, 10:22 PM   #2
Damian
Guest
Posts: n/a
Well... I fixed the line and everything is good now.
After installing the pump and filter, I tried starting the engine again after bleeding the fuel system and it still isn't getting enough fuel into the engine.
I guess it's time to check the injectors...how?
Lipp Fuel Rail Problem sprigmo1 MKIII Supra 3 02-26-2009 06:03 AM
Problem with fuel injectors! teedoff00 MKIII Supra 3 07-30-2008 05:03 AM
1980 Supra Fuel pump problem Zebian2 Non-Generation Specific Questions 2 11-20-2005 03:21 AM
