Old 02-15-2009, 12:38 AM   #1
gottadiesel
gottadiesel's Avatar
gottadiesel is on a distinguished road
Default Turbo Damage ????
In the process of doing some routine maintenance on a supra that I bought recently, I noticed damaged to the compression fins... how can this happen? It almost looks like an object got in its path. It seems to run clean and smooth on the shaft, but I assume that I should plan to replace, as I assume it is imbalanced and certainly not efficient. Have not pulled, so not sure of the condition of the turbine...
Any suggestions or advice would be appreciated.
If I am going to need replace anyway, should I plan to go to a T4? What other mods would I have to do at the same time.
New Supra Owner, 1988 5spd Turbo, minimal mods - Black Stagger Wheels Rear 225/45/18 on 18x8, Front 215/40/17 on 17x7.5. Aluminum cooler to TB pipe with SQV BOV, SS Turbo Intake with HV MAF Filter Adp.
Tunes - Kenwood Deck Driving Kenwood 1200W 2CH / Sony 1000W 2CH, Kenwood 750W Class D Mono, Rockford Fosgate 500W Mono. Amps Driving (4) 4.5 140w, (2) 6.25 200w, (2) 6x9 225w, (2) JL 10's and (1) JL 8... Yea its loud enough
Last edited by gottadiesel; 02-15-2009 at 01:38 AM. Reason: mistake in part refferring to
gottadiesel is offline   Reply With Quote
Old 02-15-2009, 07:54 AM   #2
gottadiesel
Default Added Pic
Here is a pic...
Old 03-13-2009, 06:38 AM   #3
Sellenzz
Sellenzz's Avatar
Sellenzz is on a distinguished road
Just bend it back it will prob last a few years at least.
Sellenzz is offline   Reply With Quote
Old 03-13-2009, 03:50 PM   #4
gottadiesel
Actually they are not bent, they edges are eatin up, so about 15-20% of the fins are missing and unbalanced... Actually I found a used one off of a JDM engine in great condition, paid I think $150 for it, so in the process of changing now, thanks anyway
Old 03-13-2009, 06:28 PM   #5
kwnate
SP58GT
terrible advice. Replace it or rebuild it as it appears you already are.
Nate
Old 03-13-2009, 06:40 PM   #6
gottadiesel
um yeah... Thanks...
Old 03-14-2009, 02:30 AM   #7
supradaddy0803
supradaddy0803's Avatar
OWWWW looks like F.O.D damage. Nate is right rebuild dont try to reuse that it will really blow up
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 03-14-2009, 08:10 PM   #8
mastergrader007
mastergrader007 is on a distinguished road
let me know how you make out taking your turbo off. i wanna change mine too cause i got a better one in better shape but i cant get the bolt off underneath the turbo. cant even get a wrench on it. just wondering what you did to get it off. thanks
mastergrader007 is offline   Reply With Quote
Old 03-16-2009, 06:57 AM   #9
gottadiesel
Let me start by saying, yes I was pretty certain we were talking FOD and had no plans to try and use, but was trying to be nice in my response to an absurd idea lol…
Did not find any damage past there, but found crap in the pipe to intercooler, the pipes were starting to crack on ends, so I actually have a used, but in great condition pipes and intercooler coming to replace mine, as I am concerned about were shavings and crap are sitting down in the intercooler and in the pipes….
Thanks for the comments either way…
Mastergrader007 – you asked about removing turbo. Well it is not the easiest turbo I have done a R/R on, but there are probably more difficult ones out there….
Here is what I did, I know which bolt you are referring to, certainly spent a little time myself getting to it. But I used a ?” ratchet with I think a 10” extension, a swivel and a deep socket (I think 11mm) Now the important part is with the swivel, need to use some good quality electrical tape and wrap the swivel. ( I say good quality, as you want it flexible, vs the stiff cheap crap) This allows the socket to swivel without falling over while trying to feed it up through where you can’t see. Then you just have to play the monkey arms by doing your best to reach around one way with the ratchet, while reaching around to guide the socket.
My only other problem child with that part of the project was the 90deg exhaust drop down and where it attaches to the exhaust drop down pipe. There are 3 studs with 3 nuts. I used plenty of WD40 soaked overnight etc… an impact wrench, ? breaker bar and an added 24” cheater bar… something was gonna break before the nut was going to come loose… so I did what would have been easier to begin with lol… I just dropped the rest of the exhaust and did not bother disconnecting the 90deg from the exhaust pipe…
Otherwise not a major project, I was able to find all gaskets for the exception of one that I will have to make. Well the turbo is only a small % of what I am in the process of doing right now to the car, but I hope to have on the road by end of next weekend… I have only put 100 miles on car since I bought it last month, so I am anxious to get it done…
