Old 02-16-2009, 02:06 AM   #1
RawrXTC
RawrXTC is on a distinguished road
Default Ignition coil question
Hey, could anyone post a pic of a ignition coil connecter in a turbo mk3. I have no clue where it is and I'm planning to do a compression test on one im going to look at on wednes. Thanks
RawrXTC is offline   Reply With Quote
Old 02-16-2009, 08:20 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Turbo 7M-GTE Coil Pack, Located on top of the cam covers at the front, underneath a black plastic vented cover where the oil filler cap protrudes from . You cant miss it says turbo in red lettering. I assume your intentions are to use this to reconnect the HT leads (wires) after you have finished your compression check on the engine. No 1 connects to the front spark plug No 6 to the rear plug.
Old 02-16-2009, 08:48 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Sorry miss understood your question, it all makes sense now, this should help, plug marked with red arrow.
Old 02-16-2009, 11:17 PM   #4
RawrXTC
Thanks for the picture helps a lot. Is the plug the green 1 or the white 1?
Old 02-17-2009, 01:25 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
Mines grey, but some are green as this one I found on Ebay.
Old 02-17-2009, 06:27 PM   #6
Bill UK
AEM EMS
Bill UK's Avatar
The best way is to leave that plug alone and pull the 15 amp EFI Fuse bottom right in photo. This will stop any fuel going past the fuel injectors. Less risk of damaging the wires in the plug and stops fuel going into the cylinders.
ignition mystery (what a surprise) mattfurlani MKIII Supra 0 09-27-2007 02:09 PM
Ignition / Wire Harness Question kidsusukigsxr MKIII Supra 2 07-11-2007 12:57 PM
Ignition Coil or Igniter? scruffboy Non-Generation Specific Questions 2 02-13-2007 02:13 PM
Ignition write up.. midwestmk2 MKII Supra 0 06-11-2006 02:56 AM
