Removing the oil pressure sender???
Ive searched high and low on how to remove this bad boy...but turned up with nothing. My stock oil gauge isnt working and ive checked the connection numerous times, seems there should be contact. Now i was thinking if connection is there, it probably is the actual unit. I dont want to just start yanking and turning this thing. Any info on how to remove it would be appreciated.
Im pretty sure it just pops in and out. It has a little lip on the bottom of the sender to pop in and out of the cavity on the block. So like you said just twist and yank on it and the sender should come out.
