Old 02-18-2009, 02:58 PM   #1
518Supra
518Supra is on a distinguished road
Default Differences between JDM and American 7MGTE
Hey all i have a 90 7mgte w/ a spun main bearing, everything else is fine but i need a new short block. I was talking to the supra guy that lives near me and he advised me not to buy a JDM motor, but i havent been able to find anything around here that isnt JDM. Again all i need is the short block and im just looking for differences between the two. I also apoligise if there was already a thread about this, searched a while but couldnt find it.
518Supra is offline   Reply With Quote
Old 02-19-2009, 02:30 PM   #2
518Supra
nothing??? cmon supra ppl i know some of you are pros!!
Old 02-19-2009, 04:23 PM   #3
defiant
defiant is on a distinguished road
Are you sure yours is a short block? The JDM 7M-GTE is a perfect match to the North American 7M-GTE, oh and the JDM came with the CT26 turbo. However the block is a long block.
defiant is offline   Reply With Quote
Old 02-19-2009, 06:29 PM   #4
518Supra
sory i worded it wrong, all i need is the short block. I was just wondering if there were any differences in the oil pan/pump, and if i would need a new wiring harness or something like that. I was told that the motor doesent simply "drop in" but thats only one persons opinion ya know
Old 02-19-2009, 07:58 PM   #5
btwilson86
Super Moderator
btwilson86's Avatar
It depends on what year of JDM engine you get. The 87-88's have a mid-sump oil pan, and I believe that the 89-92's have a rear sump oil pan. This change was from the introduction of the 1JZ. You will also have to swap all of your state required emissions items over, but as you said you only need a short block I'm pretty sure you know this. I know on the 7MGE's (not sure on the Turbo models), there was a slight modification to the engine in 89(?) where they counterbalanced the crankshaft at the no 2 and no 5 cylinder, which resulted in a lower redline (by 200 RPM) and requires the use of a different flywheel/flexplate.
In addition to the above stated, you may find that some electrical plugs are different (such as the oil pressure sensor), so you may need to swap your current one's over or purchase new ones.
With swapping in a JDM engine, you should plan on a rebuild. Just because it's low-mileage doesn't mean it wasn't abused, so it's a good idea to take care of that before you put it in the car and possibly have it crap out on you down the road.
Old 02-22-2009, 10:33 PM   #6
518Supra
exactally what i was lookin for, thanks for the info. Pretty sure im gunna make the drive and get a rebuilt not JDM . But thanks again!
Old 03-03-2009, 07:54 PM   #7
Mr.Bojangles
Mr.Bojangles is on a distinguished road
If you did get a JDM GTE and it came with the ECU and wiring harness, then theoretically you should be able to just drop it in (barring pan differences) and be all set right?? You should be able to use all the accessories that came with the JDM once you rebuild the motor. I might be wrong, if so someone please correct me because I am going to buy one very soon for a GE to GTE swap.
I used to believe in American horsepower until my LT1 popped at 50k miles.
Mr.Bojangles is offline   Reply With Quote
Old 03-04-2009, 01:04 AM   #8
btwilson86
Super Moderator
btwilson86's Avatar
You may need to swap some emissions stuff over (depending on your local laws and if you choose to follow them). As for the harness, I'm pretty sure that on the JDM Supras the ECU is going to be on the left side of the car, not the right like the USDM Supras. So you would want a US harness, some of the sensors, and then your ECU and engine should work fine. Or you could lengthen your JDM wiring harness.
