Old 03-03-2009, 05:28 AM   #1
87MK111Supra
87MK111Supra is on a distinguished road
Default Torque Specs
WHat are the recommended torque specs for the head bolts and cam bolts?
THanks a lot.
87MK111Supra is offline   Reply With Quote
Old 03-08-2009, 07:16 PM   #2
87MK111Supra
Does anyone know these? I'm putting it all back on there today and was hoping I could get the right specs.
Old 03-08-2009, 07:47 PM   #3
btwilson86
Super Moderator
btwilson86's Avatar
If you haven't already, download the TSRM. It'll tell you in there. As for the head bolts, are you just using OEM bolts or are you using ARP bolts/studs? Need more info before anyone could give you some useful specs.
Old 03-08-2009, 07:53 PM   #4
87MK111Supra
Where can I download that at? They are all stock bolts but I know that the original torquing of the head bolts were 58 and that's not right, they are 72 or something I think. I wanted to make sure that the cam shaft bolts were the same as stated on the original specs or if they are different like the head torque. Thanks.
Old 03-08-2009, 11:00 PM   #5
btwilson86
Super Moderator
btwilson86's Avatar
Don't know about the head bolt torque for oem bolts, cam torque should still be factory spec.
Here's a PDF TSRM:
http://www.gdscentral.net/MKIIITSRM.pdf
Old 03-09-2009, 09:37 AM   #6
Quint
Quint is on a distinguished road
For the 1G.
64Nm for the head bolts.
I'm not sure what you mean by 'cam bolts', if you mean the bearing caps for the camshaft then 19Nm
75Nm for the 7M on the head bolts, no idea on the cam caps tho.
Metric = win
Quint is offline   Reply With Quote
Old 03-09-2009, 10:58 AM   #7
ddmcse
ddmcse's Avatar
Cool
parts catalog
Electronics Parts Catalog
manual
Cygnus X1 - Supra
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 03-09-2009, 10:28 PM   #8
87MK111Supra
Thanks a lot you guys. I'm running a 7MGE.
I was talking about the bearing cap bolts. THat's my main concern about torque specs.
ct26 torque specs tak2099 MKIII Supra 0 01-28-2009 04:51 AM
factory specs? burton51m MKIII Supra 6 10-16-2006 07:44 PM
Torque specs for steering rack on mk4 dini_the_owl MKIV Supra 1 09-15-2006 11:48 AM
Need torque specs... VigilanteVixen007 Non-Generation Specific Questions 5 09-19-2005 11:47 AM
engines and specs for the mk3 suprra_girl MKIII FAQ 0 12-29-2004 12:20 PM
