Old 03-11-2009, 11:03 PM   #1
89_1j
89_1j is on a distinguished road
Default 1JZ fuel type
All of the specs on the 1JZ say "fuel type: unleaded premium." Is premium required or is it just better for it? Also, is there an easier way to do the wiring on a 1jz? Ive heard they make a wiring harness thats like an adapter when installing in a mkiii. If there is such thing where could i find one and how much would it cost?
89_1j is offline   Reply With Quote
Old 03-12-2009, 12:45 PM   #2
mirage83
As far as premium fuel goes the higher octane is used to help prevent knocking/detonation. You can use lower octane fuel (many people do), but you increase the chance of real internal damage to your engine. For myself, I don't risk it where my GTE is concerned. It's a little more expensive per gallon, but less expensive than replacing pistons, valves, etc.
Not sure about the wiring issue, have to look around on that one.
Old 03-12-2009, 05:27 PM   #3
89_1j
That's pretty much what i figured but I wanted to be sure. My baby will get nothing but the best. Thanks for the help.
Old 04-30-2009, 05:22 AM   #4
drewtiss
drewtiss is on a distinguished road
Originally Posted by 89_1j View Post
All of the specs on the 1JZ say "fuel type: unleaded premium." Is premium required or is it just better mirror for it? Also, is there an easier way to do the wiring on a 1jz? Ive heard they make a wiring harness thats like an adapter when installing in a mkiii. If there is such thing where could i find one and how much would it cost?
Yeah he's right on that matter. I also think that it's a little more expensive per gallon. I think I saw something on this forum about the wiring hareness.
drewtiss is offline   Reply With Quote
Old 04-30-2009, 10:04 PM   #5
supradaddy0803
supradaddy0803's Avatar
Yeah the price difference is kinda self explanatory the better gas is always more expensive. As for the wiring I think there a few people on here that make a plug and play harness adapter you will just have to ask around.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Tags
1jz, 1jzgte, fuel, fuel type
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel Octane scruffboy Non-Generation Specific Questions 3 09-08-2006 06:49 PM
fuel type no 1 lampy MKII Supra 4 02-28-2006 06:37 AM
