Old 03-20-2009, 11:19 AM   #1
Paul_NJ
Paul_NJ is on a distinguished road
Default Replacing Timing belt
I've been reading the timing belt removal procedure in the TSM, and it seems like they take off the belt by removing tension on the belt tensioner, then remove the cam and crank timing gears, then they reinstall the gears, and finally put the new belt on and tighten it up with the tensioner . Why remove the any of the gears at all? Is it just to replace the seals? That's not mentioned in the TSM. Otherwise it would be a lot easier to just switch belts. How difficult is getting the gears off and changing the seals? I see they call out a SST for removing the timing gears. Any suggestions on that?
Paul_NJ is offline   Reply With Quote
Timing belt tensioner HELP ! lobosupra MKIII Supra 1 12-11-2008 11:52 PM
Broken Timing Belt detroitsupra MKII Supra 3 03-10-2008 11:06 PM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
Timing Belt Change, Do It at Home mrnickleye Supra FAQ 2 09-19-2006 06:24 AM
Timing belt rubbing against lower front cover adamh88 MKIII Supra 4 01-05-2006 11:08 PM
