Old 03-27-2009, 09:19 PM   #1
mastergrader007
mastergrader007 is on a distinguished road
Default thermostat?
hello,
Just fired up the ole mk3 gte gettin it ready for summer and noticed that the coolant shot out of the overflow for a few seconds (please dont be a BHG) anyway, i noticed that when the engine got up to temp, the top rad hose caved itself in. and by that i mean, sucked itself tight together. do you think it is the thermostat??? cause thats what im hoping for. or maybe a clog in the cooling lines??? i did a compression test last year before i parked it and every cylinder was above 160psi. so what are your thoughts???
mastergrader007 is offline   Reply With Quote
installing thermostat sd88supra MKIII Supra 8 06-18-2010 02:23 AM
thermostat ethan12510 MKIII Supra 8 06-28-2007 01:40 PM
Which Thermostat? scruffboy Non-Generation Specific Questions 4 03-01-2007 11:18 AM
Thermostat Necessary? Bullz_EyE MKIII Supra 16 01-02-2007 12:12 AM
Checking Thermostat scruffboy Non-Generation Specific Questions 6 03-09-2006 05:49 PM
