Old 03-23-2009, 02:37 AM   #1
sd88supra
Question removing egr valve
I can't get to removing the old heater hose because the EGR valve is in the way. Problem is, I'm having a hard time removing the two studs that hold the EGR valve! How do you guys do it? There's not enough room for a wrench or a socket. It seems like a shortened 12mm wrench will get the bottom one out, but the top is still a problem, especially because you have to feel where they are since you can't see them. Besides I don't want to cut my wrenches.
Too bad I didn't see how my mechanic did it when he serviced my EGR.
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
Old 03-23-2009, 04:14 AM   #2
burton51m
burton51m's Avatar
The EGR Valve is a Bitch to get on and off. Took me soo long to get it. I think i ended up getting it on and off from under the car, especially that lower bolt.
Bad Proportioning Valve? georides Non-Generation Specific Questions 5 03-05-2009 03:34 AM
Air Control Valve nickvash0104 MKIII Supra 0 03-07-2006 06:26 PM
