Old 03-26-2009, 04:30 AM   #1
87-POSupra
87-POSupra's Avatar
87-POSupra is on a distinguished road
Default auto transmission issue
i put a new motor and transmission in my car from japan. the motor was perfect but the transmission wouldnt do anything. put it any gear and it didnt do anything so i pulled it out and put a different transmission and torque converter in it. still did the same thing. i just put another transmission and still nothing. im thinking im on a string of bad luck but if you have any ideas let me know.
87-POSupra is offline   Reply With Quote
Old 03-26-2009, 05:06 AM   #2
Vacationtime247
A few quick ideas and I'm not trying to sound like some smart a$$.
1. Check the fluid level and if it has a filter installed.
2. Make sure the linkage is installed between the transmission and the shifter.
3. Is the driveshaft connected
4. Make sure the engine flywheel is connected to the torque converter
VT247
Old 03-26-2009, 05:12 AM   #3
87-POSupra
87-POSupra's Avatar
i have tripple checked everything. ive done the transmission a few times now. the only thing that im a little iffy on is the fluid but im gonna double check it tommorow and try some more troubleshooting.
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Auto Transmission Swap big_kahuna89 MKIII Supra 1 06-13-2008 11:13 AM
Auto to Manual transmission? dannydavi MKIII Supra 19 05-18-2007 05:33 AM
Buzzing Auto transmission MattJ MKIII Supra 2 02-21-2006 10:40 AM
