#1 |
51: "Switch Signal"
I know I did not make the mistake of having the AC on or hitting the gas while checking the engine lights. So, could this be from a bad ISC unit? I know I have a small coolanty leak somwhere in that area. I believe where one of the hoses connects to the ISC. 52: "Knock Sensor" Uh oh... :-) Could this be from using premium gas ? |
#2 |
BUMP
Any ideas? |
#3 |
Replace knock sensors will most likely clean the problem up.
With them playing up the computer will think there is pinging and will put the car into 'limp' mode, will drive like pooze. Toyota wanted something like $398.00 +gst ea when i had to replace mine, paid $6 ea second hand, i suggest you go second hand ![]() |
#4 | |
![]() Quote:
Thread Tools | |
Display Modes | |
