Got a lock on a Supra for $1000. The owner says it produces white smoke from the tailpipe at startup only and that his mechanic says it's due to the fact that he rarley drives it. What could cause this?
Thanks!
![]() <span style='font-size:14pt;line-height:100%'>Stock...for now</span> |
Guest
Posts: n/a
Fist is the car turbo. If it is then the smoke might be coming from oil leaking from the turbo into the down pipe. It could also be a bad set of pistons rings or a leaky valve gide. Good luck.
white smoke on startup (especially in the mornings) is quite common... it's just the condensation in the exhaust steaming off from the engine warming up
if it continues permanently you have a problem ![]() also i think i stated this particular question in the FAQ SEARCH!!! LOL
#4 | |
![]() Quote:
Also, What's the difference between an 86.5 and an 87 (both NA) 'Preciate the tip!
hmmm interesting.... well i'm sure i wrote it lol
difference between 86.5 and 87 na = nothing ![]()
#6 | |
![]() Quote:
White smoke from exhaust manifold | Rommy | MKIII Supra | 15 | 07-26-2009 06:32 PM |
help! white smoke out tail pipe | tone loc | MKIII Supra | 5 | 08-04-2006 10:29 PM |
White Smoke | Drag0na5h | MKIII Supra | 1 | 04-25-2006 06:36 AM |
NEED HELP...Does white smoke = BHG? | 87sleeper | MKIII Supra | 10 | 01-11-2006 12:38 AM |
white smoke | steve119md | MKIII Supra | 5 | 05-24-2005 08:57 PM |
