Old 04-09-2009, 12:17 PM   #1
Paul_NJ
Paul_NJ is on a distinguished road
Default New Timing Belt Direction
Finally putting things back together.
I've read the timing belt is directional, and facing the engine turns clockwise from left to right, but my new (from Toyota) belt doesn't have any arrows on it.
Looking at the belt there's Totota labelling, then to the right of that there's the part number, and then to the right of that there's 5 vertical lines. Should the words be readable as you face the engine from the front? If so, then the 5 vertical lines would indicate the belt turns in a clockwise direction.
Anyone put a belt on recently? Would appreciate you're checking me on this.
Thanks
Paul_NJ is offline   Reply With Quote
Old 04-10-2009, 09:29 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
The directional thing only applies if you are reusing your old belt. Before removing the old belt, mark it with an arrow so you can install back the same way it came off. A new belt can run either way no directional preference, providing the ribbed face is facing inwards of course.
Old 04-11-2009, 01:16 AM   #3
Paul_NJ
Thanks Bill. I really wasn't sure if the belt direction made a difference or not. I appreciate you're clearing that up. The timing belt installation sequence on the UK Supra site for which you provided the link was excellent, and helped a lot. The new idler pulley and timing belt fit up fine. Next to breaking the crank pulley bolt free, I think the worst part of the job is going to be replacing all of the vacuum lines.
Replacing Timing belt Paul_NJ MKIII Supra 5 03-21-2009 05:35 PM
Timing belt tensioner HELP ! lobosupra MKIII Supra 1 12-11-2008 11:52 PM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
Timing belt rubbing against lower front cover adamh88 MKIII Supra 4 01-05-2006 11:08 PM
timing belt for 86.5 NA sd88supra MKIII Supra 1 12-29-2005 02:05 AM
