#1 |
Finally putting things back together.
I've read the timing belt is directional, and facing the engine turns clockwise from left to right, but my new (from Toyota) belt doesn't have any arrows on it. Looking at the belt there's Totota labelling, then to the right of that there's the part number, and then to the right of that there's 5 vertical lines. Should the words be readable as you face the engine from the front? If so, then the 5 vertical lines would indicate the belt turns in a clockwise direction. Anyone put a belt on recently? Would appreciate you're checking me on this. Thanks |
Replacing Timing belt | Paul_NJ | MKIII Supra | 5 | 03-21-2009 05:35 PM |
Timing belt tensioner HELP ! | lobosupra | MKIII Supra | 1 | 12-11-2008 11:52 PM |
Photos of my timing belt | Nato99 | MKIII Supra | 7 | 08-27-2007 09:33 PM |
Timing belt rubbing against lower front cover | adamh88 | MKIII Supra | 4 | 01-05-2006 11:08 PM |
timing belt for 86.5 NA | sd88supra | MKIII Supra | 1 | 12-29-2005 02:05 AM |
