Old 04-16-2009, 02:07 AM   #1
Paul_NJ
Paul_NJ is on a distinguished road
Default Is this a vacuum line?
I'm in the middle of changing my (original) vacuum hoses to silicone, and the device down below the turbo, on the left side with a "Toyota" sticker on it and with one hose coming out of it, isn't on the hose diagram posted elsewhere on this site. (1987-MKIII) Can anyone identify what the device is? More importantly is that a vacuum line coming out of it that should be changed?
Paul_NJ is offline   Reply With Quote
Old 04-16-2009, 03:32 AM   #2
Cyberguy1992
Cyberguy1992's Avatar
Cyberguy1992 is on a distinguished road
I'm sure its a pressure line and yea if its not silicone change it... if you get 2 kind of long pieces of silicone hoses that thickness and put a pressure regulator in the middle you can adjust the amount of boost higher than 8 Lbs..
Cyberguy1992 is offline   Reply With Quote
Old 04-16-2009, 04:20 AM   #3
Paul_NJ
OK. I just read that that is the waste gate actuator, and it controls the bypass valve on the exhaust side of the turbine, based upon the pressure on the inlet air side of the turbine. I suppose it wouldn't hurt to change it's pressure hose.
Old 04-18-2009, 10:32 PM   #4
spudz29212MKIII
spudz29212MKIII's Avatar
Yea waste gate actuator. Def change that, you don't want some crappy hose on that or you might risk blowing the turbo.
Zach
Where is this vacuum line saposed to connect to? mkiiisupra MKIII Supra 15 07-15-2010 05:15 AM
Vacuum line routing to HKS SSQV? mkiiisupra MKIII Supra 8 02-06-2008 05:29 AM
Vacuum line help 91toy supra MKIII Supra 7 08-25-2006 11:32 PM
Vacuum Line Deletion? Bullz_EyE MKIII Supra 1 12-24-2005 06:37 PM
vacuum advance/retard tonster MKII Supra 0 09-16-2005 06:43 PM
