Old 04-21-2009, 12:29 AM   #1
skadaloz
skadaloz is on a distinguished road
Default help, no start after replacing HG
like title says...i just replace my head and headgasket, cranks but not start....cranks freely like no combustion happening...fuel pressure is at 25-30 psi key on....has spark but looks weak....any clues would help
skadaloz is offline   Reply With Quote
Old 04-21-2009, 01:25 AM   #2
mirage83
Check your CPS alignment and the timing, CPS especially as it doesn't have to be off by much to keep the engine from running. While you're at it check the air-gap measurements on it, see what kind of shape it's really in.
Old 04-21-2009, 05:54 AM   #3
h8z2luze
h8z2luze's Avatar
h8z2luze is on a distinguished road
Go through once more make sure everything is connected. I had the same problem until I realized i hadn't reconnected my MAF sensor lol.
1989 Supra 7MGE MK3 5-speed project...
http://www.cardomain.com/ride/2385505
h8z2luze is offline   Reply With Quote
Old 04-21-2009, 01:59 PM   #4
Makz
Makz is on a distinguished road
Check the installation of cam position sensor.
ex '87 MA70 7M-GTE, A/T, targa, rhd
ex '87 GA70 1G-GTE, M/T, targa,rhd
now '90 JZA70, 1JZ-GTE(swap), M/T, targa, lhd
18 inch PIAA Rozza wheels, HKS blow-off, Apexi turbotimer, XTD stage 3 racing clutch, AEM air filter, JZA80 fuel pump, 4-piston Skyline GT-R front brakes, Blitz boost-controller, high performance exhoust system
Makz is offline   Reply With Quote
Old 04-22-2009, 12:52 AM   #5
skadaloz
i retrace everything(sensors/plugs/wires/vacuum), its all plug up and recheck timing and it was right on, readjusted cam sensor but where is the crank position sensor b/c i didnt remove crank pulley and lower timing cover at all b/c i just used my old timing belt
Old 04-22-2009, 11:46 PM   #6
skadaloz
this is wat i got on my check engine light...
blink..blink.....blink..blink.....blink..blink.... .blink..blink..blink..blink
so is it code 22 and 24?
Old 04-23-2009, 01:51 AM   #7
mirage83
That's what it reads to me, water temp sensor and air temp sensor. Check your wiring for them, hope that's all it is, a loose couple of connectors.
Old 04-23-2009, 11:49 PM   #8
skadaloz
well got that fix...it was my water temp sensor, the wire to the plug was corroded and i touch it and fell off...so i rewire it and now no codes...but still wont start...so i redid the timing and redo the cps as what the TRSM says and still no start...sounds like it wanted to start but then just goes back to crankin fast...well ima try to recheck everything again and see if it starts
Old 04-24-2009, 07:57 PM   #9
skadaloz
well just did a compression test and theres no compression....so i did a leak down test and 100% no leaks...its weird theres no compression but theres no leak on any of the cylinder?
Old 04-24-2009, 09:21 PM   #10
h8z2luze
h8z2luze's Avatar
Maybe you have bad rings or bad valves...
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
