Old 04-24-2009, 05:19 PM   #1
SupraTaylor
SupraTaylor is on a distinguished road
Default Transmisson Swap 1987 NA mk3
MY AUTO transmisson is going out in my 1987 supra and i was wondering what was needed to put a 5 speed manual Trany (auto sucks) in. I would appreATE ALL the help i can get
SupraTaylor is offline   Reply With Quote
Old 04-24-2009, 05:39 PM   #2
Kevin
You would need a manual gearbox, bellhousing, driveshaft, clutch and brake pedals, clutch master and slave sylinder, a clutch and clutch line... anything else im missing? ecu maybe? idk.
Old 04-24-2009, 05:42 PM   #3
SupraTaylor
Now the Auto Tranny in my 87 has like a power Button and lights for that stuff is that stuffg going to interfere with the 5 speed???
Old 04-26-2009, 12:07 AM   #4
Kevin
Are you talking about TEMS? The sport button and comfort button with the 4 lights? Correct me if i'm wrong.. im not familiar with the automatics. If it is the TEMS then it shouldn't interfere
Old 04-26-2009, 04:05 AM   #5
SUPRAMAN3468
SUPRAMAN3468 is on a distinguished road
i also need another wiring harness, the wires that go to the tranny r
totally different
SUPRAMAN3468 is offline   Reply With Quote
Old 04-26-2009, 04:59 PM   #6
btwilson86
Super Moderator
btwilson86's Avatar
The auto tranny has the "Normal" and "Power" mode, basically alters the shift pattern of the transmission. I do believe you need a new harness, so those won't matter. However, your gauge cluster will still have an "O/D" spot on it, whereas the manual obviously does not. Also I am pretty sure that your gear in the differential are different to compensate for the 3 speed w/overdrive auto tranny versus the 4 speed w/overdrive manual tranny.
You should get the proper ECU for the engine and transmission combo you plan on running, otherwise you will probably have a CEL on all the time for the "Neutral Start Switch" and would need to hardwire your reverse lights for them to work.
So you should get:
Complete transmission (bellhousing, gear box, etc.)
Fywheel
Clutch
Master and Slave cylinders
Brake and Clutch pedal assembly
Clutch lines
ECU (optional)
Wiring harness (optional)
Driveshaft
Rear Gear
Gauge Custer (optional)
That's all I can think of, I know some of it has been mentioned earlier in this post, thought I'd make it easy ot see
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
NA->T swap and convertion questions 5+4=9 MKIII Supra 6 03-02-2006 02:11 AM
1987 Engine Swap Johnny boy 82 MKIII Supra 1 10-01-2005 01:26 PM
