Old 04-24-2009, 11:16 PM   #1
craig
craig is on a distinguished road
Default ? with bearings
im buying a bearing kit for the crank and rods. i took the old bearings to a toyota dealer and they said that the factory bearings are mark 2 and that i have to order them from them. problem is they want 2 times the amount that i can get standard one from another source. has anyone ran into this problem? or is the dealer full of shit?
craig is offline   Reply With Quote
Old 04-25-2009, 04:38 AM   #2
SUPRAMAN3468
SUPRAMAN3468 is on a distinguished road
that the crank and have it checked for wear and ask cam u use the factory bearing r if the need to shave the crank best bet
SUPRAMAN3468 is offline   Reply With Quote
Old 04-25-2009, 11:26 AM   #3
craig
the crank is fine and the cam bearings are fine. i just want to replace the crank bearings and rod bearings. but the problem im having is the dealer says i cant use aftermark bearings. they are saying i have mark 2 bearings and that the factory used 5 different size bearings. mark 1-5 basicly has anyone uses standard bearings in there engine? and how was your oil pressure.
Rod bearings went out... OmeGa MKIII Supra 2 04-17-2008 02:08 AM
Turbo bearings robwpe Non-Generation Specific Questions 2 11-19-2007 03:31 PM
pistons, rods, bearings supraman121 MKIII Supra 0 12-13-2006 02:48 PM
Wheel bearings nickalvrz Non-Generation Specific Questions 1 08-25-2006 06:52 PM
