Old 04-14-2009, 02:31 AM   #1
grabber
grabber is on a distinguished road
Default Erratic Idle
My 7M idles terribly. When its cold it raises idle properly, but once warm jumps from 1000-2000 rpm's or so back and forth. I have checked the Throttle Position Sensor, the Idle Speed Control Valve and the Cold Start Injector in the way the FSM says and they all check out good... I'm lost and need to fix this, as the truck is close to ready to drive.
P.S. it is not pulling a check engine light, or any codes. Thanks for any help!
grabber is offline   Reply With Quote
won't idle 3.0trd MKIII Supra 6 06-15-2009 07:23 PM
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
Erratic Idle motosparky MKIII Supra 18 06-26-2007 09:35 PM
'92 7MGTE- high and unstable idle liona MKIII Supra 7 02-04-2007 03:18 AM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
