#1 |
I have a 1987 toyota supra, turbo with a 340E trans. Problem is it shifts from first to fourth instead of first to second. Overdrive light gives a malfunction code of 63, which indicates a bad number two shift solenoid. Since the number one and number two solenoids are the same part number, I need a picture that shows me which is the number two. I also would like to know if I have to remove the valve body to replace this.
If any one can help I would appreciate it! Thanks Fullon |
#2 |
yea i have a similar problem except code 62 on the selinode 1. mine skips gear 1! i am trying to find which selinode is which also but i do know this, they changed pulling pan only.
ABS Problem? | rasclaat_98 | MKIII Supra | 6 | 12-13-2010 09:53 PM |
speed sensor problem | nadircicek | Non-Generation Specific Questions | 8 | 10-09-2009 05:58 PM |
another heater problem | nicnet | MKIII Supra | 16 | 12-05-2007 10:18 PM |
Trans Mount Change | mrnickleye | Supra FAQ | 0 | 02-20-2007 05:24 AM |
Nissan Sentra Tranny problem. | redmaro | Off Topic Forum | 2 | 11-28-2006 01:58 PM |
