Old 05-18-2009, 06:53 PM   #1
cgreiner
cgreiner is on a distinguished road
Default Clutch - Adjustable ?
Currently my clutch pedal does not rebound fully from the depressed state. It comes back about 1/3 of the way. Over time, it will return the full travel (~5 sec), or with a slight tap of the toe upwards. Otehrwise, the car runds great and the clutch appears to function fine. Any suggestions? Is this something I can adjust?
87 Turbo.
cgreiner is offline   Reply With Quote
Old 05-19-2009, 10:15 AM   #2
ddmcse
ddmcse's Avatar
Cool
master clutch cylinder is gone . you can replace it
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 05-19-2009, 01:17 PM   #3
cgreiner
Apparently, I was out of fluid in the clutch reservoir. I refilled and it solved 60% of the poblem. I think I still have the bleed the line. Anyone know how to do this or where the purge is ?
Old 05-20-2009, 10:11 PM   #4
dunewarz
dunewarz is on a distinguished road
It's right under the car on the tranny. You'd probably see it easy if you're car isn't rusty.
dunewarz is offline   Reply With Quote
Old 05-21-2009, 03:52 PM   #5
ddmcse
ddmcse's Avatar
Cool
why else would you lose fluid ? probably spotting the floor by now
bleeder valve is on the slave
My Supra KiXGaS
Clutch kit for a 1993 JDM Toyota Supra SpRuCe Non-Generation Specific Questions 0 04-13-2009 10:20 PM
