Old 05-20-2009, 04:34 AM   #1
mamory
mamory is on a distinguished road
Cool New supra, computer problem, turbo problem?
I just acquired a 1988 automatic supra turbo. I am fairly new to supra's and very new to and auto turbo. The car is immaculate with 130,000 miles on it. The car runs great, idles great and drives down the road flawlessly. Now the problem...first of all the speedometer does not work and i can hear a gear grind sound behind the speedometer. If there is a quick fix for this?i do not know. Secondly when i accelerate I am getting no power and major hesitation. I can slowly press the pedal down or mash it WOT and the same thing happens. It lags and will not really go above 4000 rpms. I can see the turbo gage working when i accelerate it is going up to about 7 ps and usually stays there as long as i hold the pedal down. The car stutters and feels like it is confused. Shifting differently everytime i press down th pedal. I also noticed while on a neiborhood cruise tongiht the O/D light on the dash started to blink/flash a few times...is this a code?does this have to do with my spedometer?could this maybe all be tied into the acceleration problem?? any advice or help would be greatly appreciated. thanks
mamory is offline   Reply With Quote
Old 05-20-2009, 08:00 PM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Flashing O/D light means an electrical problem in the Auto Tranny. Could be the cause of your odd shifting (maybe even your acceleration depending on if it's slipping or something). Gear grinding sound might just be the speedo cable barely touching the meter. Speedometer cable's on these cars just plug into the back of the gauge cluster.
Old 05-20-2009, 10:02 PM   #3
dunewarz
dunewarz is on a distinguished road
Most likely it's a timing problem. Check you cam position sensor. Check you timing with a timing light. Make sure you also check you tps as it can cause hesitations and bogging at low rpms if not in the correct position.
dunewarz is offline   Reply With Quote
Old 05-21-2009, 03:53 AM   #4
kwnate
SP58GT
Replace the speedo cable.
Nate
Old 05-21-2009, 04:54 AM   #5
mamory
Smile thanks for hel[!
So...tonight i took apart my gauge cluster. I found that the square nuylon/plastic part of the cable which goes into the back of the speedometer was stripped to a sharp point like a tooth pick. I will be looking into getting a replacement cable and replacing. then should i disconnect the battery to reset computer?
thanks again
Tags
acceleration, hesitation, o/d, overdrive, speedometer
newbie....problem w/ 91 supra turbo skadaloz MKIII Supra 4 04-18-2008 08:39 PM
turbo problem gemstone Non-Generation Specific Questions 2 10-25-2005 09:03 AM
overheating problem on 1990 supra turbo suprasux MKIII Supra 16 06-13-2005 10:39 PM
