Old 05-21-2009, 01:09 AM   #1
irving216
irving216 is on a distinguished road
Default please
so i went today to check out a 90 supra, 7mge, dude told me its jdm but im not too sure about that, im kinda set on not geting it because when i talked to him about it he said that all he had to do was put the throttle body back together and it would start, but he had no clue how to cuz when i got there he messed it all up and there was hoses going to no where, and since im only 17 im not really up on knowing how to hook it all up right, what im asking is there someone here that has a pic of a jdm 7mge or knows of a way to check if it is one thats kinda quick, i got this guy down to 900 for it from 1100, but even then i think its a little high for what he needs, it needs trim, paint, interiors a lil messed up, drivers door dont open, tps, clutch cylinder and the starter is messed because he has a switch for the ignition instead of the normal key ignition, i really like this car but for a tight buget, just to get it running sounds like it might be a pretty big chore
irving216 is offline   Reply With Quote
Old 05-21-2009, 03:17 AM   #2
dunewarz
dunewarz is on a distinguished road
Sounds like a bad buy. JDM 7m and US 7m. I'm not even sure there's a difference. If it was a 1jz maybe you'd be able to tell the difference. If there's wires everywhere then he's obviouly lying to you about putting the throttle body back on and getting it to work. Tell him to do it and you'll buy it just to see his reaction.
Unless you have time and knowledge of the car I'd suggest not wasting your money on a potental failed project.
dunewarz is offline   Reply With Quote
Old 05-21-2009, 12:19 PM   #3
irving216
ok thanx and i have general knowledge from working on cars but not really too much on supras and thats what i was gonna do today, tell him id definatly buy it if it was running
Old 05-21-2009, 05:36 PM   #4
86.5 7MGE
86.5 7MGE's Avatar
Cool
Here is a pic of my 7MGE engine bay maybe this will help you out a lil bit...
Name:	Project Supra 004.JPG
ID:	1999   Click image for larger version
Name:	Project Supra 005.JPG
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 05-21-2009, 05:43 PM   #5
irving216
thank you it helps a little bit, i kinda need to see the throttle body more because i wanna see how its hooked up but ya thats exactly what it loks like except the kid took off the cam gear cover to show off his stock cam gears hahaha and a few other things but thank you very much, iv decided that imma buy it, but go to him with 700 cash figure that should make him just say ya
Old 05-21-2009, 08:56 PM   #6
86.5 7MGE
86.5 7MGE's Avatar
Thumbs up
Sounds good glad I could help
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
