Old 05-21-2009, 06:08 PM   #1
Ogheen
Ogheen is on a distinguished road
Default Cigarette Lighter not working
I have an '87 Toyota Supra and the cigarette is not working. I plugged the lighter in a different car and it works fine.
My guess is I either have a fuse problem or there is something wrong with the lighter. The thing is I'm not that savvy with cars and if its a fuse problem I have no idea which fuse it will be that would be for the lighter. Anyone has any idea?
I would like to rule out a fuse issue before I go for taking out the dash and figuring out if there is anything else wrong with the lighter.
I don't smoke but its my only power outlet and it is frustrating that it's not working.
Ogheen is offline   Reply With Quote
Old 05-21-2009, 08:52 PM   #2
86.5 7MGE
86.5 7MGE's Avatar
Smile
I'm not sure what fuse it would be, but u can take a fuse puller that comes with the fusechecker and put it on the fuses while they are still in there to check all of your fuses. You don't have to remove the whole dash to check the wiring of your cig lighter just remove the ash tray take some bolts out and the dash part that goes around your shifter pops out and you can reach your cig lighter.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Headlights not working SilenceboneSupra MKIII Supra 1 01-08-2009 10:08 PM
ciggarette lighter Japanese supra tt MKIII Supra 5 06-12-2007 12:38 PM
why is my alarm not working? burton51m MKIII Supra 4 06-17-2006 05:54 AM
boost guage not working! flight doc89 MKIII Supra 0 01-29-2006 07:53 PM
