Old 05-22-2009, 01:24 AM   #1
thakiller009
thakiller009 is on a distinguished road
Default radiator problems
ok when i put water in my radiator the next day there is none in it could you guys help me with this problem it leaks from the bottom is there like a hose or somethin that could be busted
thakiller009 is offline   Reply With Quote
Old 05-22-2009, 01:37 AM   #2
mirage83
There's a lower radiator hose and probably a drain valve on the bottom of the radiator itself. If the hose is loose or split it could leak, or the drain valve might not be closed completely and allow the water to leak out.
Check for both, as coolant loss is a big no-no with a 7M.
Old 05-22-2009, 01:48 AM   #3
thakiller009
where is the drain valve located at
Old 05-22-2009, 03:26 AM   #4
mirage83
On practically any radiator it'll be on the backside-bottom of the housing facing into the engine compartment or straight down, but I suppose there's some oddballs out there that are different.
